There is life-threatening voltage of up to
250 V on terminal block. Any connections to the device and maintenance
work should be carried out only when the device power is turned off.
Do not allow moisture to contact the output connector and the internal electrical elements of the device. It is forbidden to use the device in corrosive environments containing acids, alkalis, oils, etc. in the atmosphere.
